forscan?
firstly, i would like to apologize, i have been searching for few hours on this but no luck.
i have typed in 'which forscan to get?' but i cant seem to find which usb i need to get, i have found the software and ebay has loads of them.
any help please guys?
many thanks
1 hour ago, unofix said:
many thanks
will have a look at that.
The other option, although a little more expensive, would be THIS one. Same reputable source, tried and tested by many, but this one is what you would call 'future proof'. It has the newest tech and is faster, it's also the one that Forscan recommend now.
The one in the link above is absolutely fine too, I've never had any problems using either.
thank you
i dont have any codes that popped up, just needed to find out which one to get so i can get ready to get it.
If you are new to FORScan then it would be a good Idea to have a read at this user guide before you get set up. There is also a How to section for more advanced things on the FORScan site.
 https://forscan.org/documentation.html
thank you
i will have a good read on that.
  • 2 months later...
On 6/19/2022 at 11:34 PM, unofix said:
hello
is that connecting lead still the one to get as i am thinking about buying one now?
and that software too?
Also see the Forscan officially recommended leads and devices on this page:
https://forscan.org/download.html
The new all singing and dancing 'vLinker FS' cable for £34 is the future proof lead for FORScan. Just remember nothing is ever future proof.
On vehicles 2013 and older there is no benefit to be gained using the vLinker FS cable other than the auto switching between MS and HS canbus.
A good quality ELM327(modified) cable for £20 will do everything you could need on an older car. You can even get them with auto switching for £25, but if you are thinking of doing that, then you may as well buy the vLinker FS cable.
vLinker FS: https://www.obd2shop.co.uk/wholesale/vgate-vlinker-fs-elm327-for-ford.html?gclid=CjwKCAjwvNaYBhA3EiwACgndgjvb7mpvylVx5Dqj68BxZkYIpj9XxVRz3s9B9AIME0Nl1b7X_g3EDBoCcCwQAvD_BwE
ELM327(modified): https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
ELM327(auto switcher): https://tunnelrat-electronics.fwscart.com/USB_Auto_Switch_Modified_ELM327/p4541936_19965062.aspx
many thanks again
i have a spare laptop and all i want to do is connecting the laptop to my car and check any codes and maybe change some codes like hi-jack and auto lock.
i will buy the first link and second link and i should be good to go?
You only need one lead.
apologies, i meant i will get the modified one( second link) as that sounds better.
  • 6 months later...
hello unofix,
you dont happen to know if the modified one will work on a mk3.5 do you?
reason i am asking is because my brother in law is swapping his steering wheel for one with cruise control and i have read that it will need programming after.
Yes. 👍
  • 2 months later...
On 3/19/2023 at 12:20 AM, unofix said:
Yes. 👍
Update:
My brother in law bought the modified elm327 and we used my mini laptop and was straight forward, he was very happy that we activated the cruise control. With an added bonus he told me that he didn't want the elm327 anymore and gave it me.
you don't need to use an archaic bit of rubbish - the benefits having a more stable, more capable and more compatible one... isn't worth the few pennies cheaper fighting a cable that should have been in a skip 1O years ago
after all they are still finding bugs and comms needs for the current auto-switching cables by vlinker and ODBLink
BOTH just had new firmware's in the last month and last just week, forscan amended their tool to work around a flaw in the behaviour of the best vlinker cable....
