Multiple module failure all at once. Alternator?
1 minute ago, wavemeister said:
Hello all I wonder if this is what I need to do to cure my similar problem
I have 2011 Titanium X and the initial fault came up
Tyre Pressure sys fault - service required
I now have
Hill start assist not available
The stop start light permanently on
Auto park malfunction if I try to use it
Sounds very much like a speed sensor - all of those modules rely on the vehicles speed. However, your TCS and ABS would also be disabled. Do you have these errors?
Get your battery checked at a garage, it's free and that'd be the first thing I'd do.
Yes the ABS, TCS and Tyre symbol are all lit. Is this something my local garage that does my servicing can fix or do I need to take it to a Ford garage?
If you can take a wheel off and have a screwdriver, you could do it yourself for less than £20...
I now have
What I see of all these warning lights being on, the only way to find out is to have a good diagnostic done to find the problem I did not have the tyre pressure fault or service light come up only Hill assist, abs, anti skid, auto park ,city stop, lane control as far has I remember well worth the £40 diagnostic then only charged me for the sensor no fitting charge but only took 10min's to fit.
Hello allan h did you take it to a local garage or a Ford garage?
LOCAL GARAGE with a good diagnostic
