Service Now and goes into limp mode
Hi All,
Please could you help me i have had this issue for over a year now car drives fine all time i can floor it in all gears no problem but when im at low revs in 6th gear and put foot down as it boosts for about 2/5 secs  then it cuts out and goes into limp mode with service now. if you turn ignition off and leave for 30 secs everything fine again. i just brought fault code reader and it says there no previous faults even when its actually happening it finds no faults.
Just like some advice to which root i should go down next. Ford focus st diesel 2015 thanks
Use Forscan instead of a generic reader.
Il buy one now cheers
FORscan is free to download, but you will need to buy a ELM cable around £20.00 ish either the V linker or the modified, DONT buy the wifi version theyre a pain to connect.
7 minutes ago, unofix said:
It still gives me a smile when I see the VLinker FS title.
Does the F and S actually mean anything apart from the obvious suggestion ?
depends on where your mind goes with F + S
Fo' shizzle.
I thought it might have been another one of @StephenFordenterprises but the F and S are the wrong way round 😂
When was the fuel filter last changed?
I had similar symptoms and a new fuel filter fixed it.
Actually, when mine went into limp home mode it was the traction control icon that came on, but I still think it's worth considering.
Blocked CAT??
1 minute ago, VFR800 said:
Blocked CAT??
Sounds like a job for imodium, best check with the vet first 😂
Think you're confusing Immodium and Senokot, that poor cat will be blocked for another week now!! :laugh:
Oh dear 🤔
That's what happens when using a mobile instead of a laptop 😂
Just having a meal in the hotel ready for the Ford Fair tomorrow. Loads of cool Ford's here in the car park.
13 hours ago, unofix said:
Oh dear 🤔
Air- conditioned car parking whatever next
Any update?
On 8/13/2022 at 9:01 AM, Johnbie said:
Hi All,
