Add blue
Hi all hoping for some help, have a 2018 transit connect with adblue fault and no start in 63 miles. I have tried to plug in but no communication to reductant ecu. I've found a fuse under bonnet fuse 70 and it keeps blowing. I can remove the wire from c2 plug and it's an earth however when disconnected the pin on fuse box it live so soon as connect it blows am assuming a short some were but I carnt locate the add blue ecu to disconnect and see if stops blowing with the wire disconnected the fuse doesn't blow.
