Stuck in Reverse Gear
Have a 2017 1.25 Zetec manual (31k miles) and the other day while reversing we would not get it out of reverse gear, also bite point was almost on the floor. Turned ignition off and restarted car and issue disappeared immediately and having driven it this last week has not happened again. Anyone else experienced this as cannot seem to find much out about this anywhere, many thanks.
Check the gear cable/linkage
It is becoming a common issue:
  • 3 months later...
Hey , did you find out what this was ? Mine does this quite often now I really don’t want to pay for a new clutch 😞
I've had this happen with a Fiesta in the past and it turned out to be the clutch slave cylinder.
  • 4 weeks later...
Hi, so a quick update on this issue as the problem seemed to be happening more often when crawling in traffic. Eventually managed to speak to an experienced Ford mechanic who advised it was most likely the master cylinder suffering an internal leak and he described the same symptoms when stuck in traffic. Upshot is master cyclinder replaced but also the bottom pipe that comes out of it in the engine bay as seemed the original pipe was not sealing correctly. This was done about 4 weeks ago and since then have had no further problems so hoping that is fixed now.
See attached highlighted by red arrow -
  • 1 year later...
Hi, I’m currently having the same problem. Gear is sticking either in 1st gear or reverse. Doesn’t do it all the time but is getting more often. Had the clutch bled and resolved the problem for a couple of months but it’s happening again. Has anyone else had any joy replacing the master cylinder rather than a new clutch? Thanks
4 hours ago, Jo-123 said:
...Has anyone else had any joy replacing the master cylinder rather than a new clutch? Thanks
Yes, the bloke that made the post just before yours 🤣
Hi Marty99, just wondered if you have had any further issues after replacing the master cylinder since your last post?
