Help System switched off to save battery
Looking for some help. My 2020 fiesta vignale kept coming up with a msg on the dash, Sysem switched off to save battery... this happened before, and eventually the battery died. I got it replaced about 3 months ago and the messages stopped. Now the message is back and I think something must be draining the battery. Any help would be appreciated
Hello Brian,
There are literally dozens of threads on this topic, this most recent one sums up the issue:
https://www.fordownersclub.com/forums/topic/141460-2021-eco-boost-battery-issues/#comment-972391
This is not just a Ford problem, most modern cars with so-called "smart" charging systems for emissions reasons suffer in the same way.
As an example there is a massive thread on the Toyota owners forum on exactly the same issue and the answer, I'm afraid, is the same - buy and regularly use a charger such as those recommended in the thread above.
I had exactly the same problem and this has worked for me, though I found out the "cure" quite early in my ownership and am still on the original battery.
Search this forum:
State Of Charge      OR    (SOC)
You will need a decent Smart Battery Charger. One that is quite popular is the 'Maypole' available from Amazon for around £24
You're after @StephenFord's job again!😀
