White screen
Hi, recently my sat nav screen keeps flickering then the screen goes white. I’ve changed the fuses but it has made no difference. The radio systems still works. Has anyone else had this problem ?
Most likely the screen itself at fault.  Easily replaced with a used one.  Though I would just check the plugs aren't loose on yours first.
I’ve check all the plugs and they are ok. I’m having problems trying to find a replacement screen I’ve looked on eBay and had no luck finding a sync1 screen.
Try local breakers yards, I think most Mk3 PFL's had the same screen.
Depending on where you are in Essex, I can recommend Autobreak.
