Ford focus
Hi everyone im looking for some advice i have a 2011 ford focus eco boost witch had few peoblems the inside fans horn and rear wiper not working how ever it was due to faulty battery and once that was changed it all started working again untill couple days ago the three problems have began again any advice on what it could be ?
BCM, fusebox under glovebox. Check for water ingress, early MK3s had a recall for it
As Dave has correctly said, most probable cause is water ingress in to the BCM which is a common problem for your model.
