Oil clip on Sump plug
Guys I did a oil change but I can't remember which way the clip should be fitted. It's the only way I could get it to fit is this OK and also what is the A switch for.
It's for switching on the Annoyance, just leave it turned off you will be much happier and so will the car.
Stop-start switch 🙂
The A is for 'Auto stop start'.
Sump picture isn't clear but as long as the R Clip is through the cut-out and covering the plug it should be fine.
Product Automotive design Grille Mesh Automotive tire
