Ford Focus Ecoboost 1.0 2013
Hello, I don’t know if anyone has come across this issue the best way to explain it is. My car drives perfect and about 30 mins into driving sometimes if I accelerate a bit to hard I loose power and turbo stops boosting. If I switch the engine off and back on it is back to normal. Also, “Engine Malfuction” light comes on when the car stops boosting.
It could be partially blocked fuel filter.  So under gentle fuel flow there's no problem, but there is when you try to push it.
But a proper fault diagnosis using the OBD port would give you more info.
Then all you need to do is use FORScan and read the DTC to find out what the problem is.
