Having trouble updating latest map
the files I have are 1222420543_20230404_1546151.thumb.jpg.a4d29acd82aeed1997c25f4f58997b61.jpg
 Tried Unzip with 7 Zip but it seems not very successfully
Thank you for your reply, when I inserted the USB stick I had a message appear indexing finished did not get
  • Installation Complete pop-up will appear on your vehicle’s onboard screen, and did not see a log file on my USB stick, tried updating via Wifi no updating on that either so now any time I go onto the Ford site there will allways be waiting for updates to be completed.
You are not supposed to further unzip the download, the car will unpack the files in the SyncMyRide folder. Nor should you open or edit the autoinstall.lst unless you REALLY know what you are doing. This is just the update "instructions" for the car to read.
Also it should be noted, this seems to be an errornous "update" as it is just the log file, not a map update.
I'm sure Ford will withdraw or change it at some point
"I'm sure Ford will withdraw or change it at some point"
but don't hold your breath!
