Upgrade 2013 Edge radio to DAB?
Heya, now my mk3  Edge is working properly and on the road (woohoo) , i would like to change the radio. Been given a dab unit from  a zetec  (a friend change theres to a newre one), so how hard to change the radio and screen for the newer one? Will bluetooth work etc? Thank you
So  plugging the head unit in, im missing 1 extra aerial connection and a second block that can be added? Any diagram or what am i missing?
https://www.fordownersclub.com/forums/topic/42898-ford-focus-full-wiring-schematics-mk225-and-mk3/
aha, sadly a full eletric diagram is above my tech skills 😞
was hoping for a iring digram for the radio harness (and the dab radio output plugs) along with the bluetooth module.
update - can answer my own question - the wiring for everything is already in situ (inc sat nav if i wanted it) - change radio/screen and bluetooth module and voila
  • 4 weeks later...
However, im getting Error U2101, not sure if DAB is working and cannot connect my phone ?
Does it need a new steering wheel?
Have you used FORScan to enable the DAB option ?
I can access APIM but not ACM; where else would i need to look (other modules). Where can i find the `as built` ?
