Realign front washer jets
Hello
I've only had my new focus since December last year and already somehow, the passenger side washer jet doesn't spray onto the windscreen. It sprays mostly onto the passenger side of the car/ top corner of the windscreen where the wipers don't reach.
Ive looked at the jets and as they aren't the ones will the adjustable balls I've seen before, I wanted to check if they are adjustable andbif so how how to do it. Quite disappointed that they e managed to come out of alignment so soon.
They are not adjustable.  Chances are there's a bit of muck lodged in the jet altering the angle.  If you've got access to compressed air, you can remove the washer pipe and try to blow any muck through.
1 hour ago, TomsFocus said:
...If you've got access to compressed air, you can remove the washer pipe and try to blow any muck through.
Or, you can go old school and simply blow through the nozzle really really hard! :biggrin:
stick a pin in it
