Engine light
Hi guys,
I need advice. For the better part of a year and a half, my car has had an issue with intermittent engine light coming on and off and I keep getting the error on my FordPass app which I've attached. I've had it with the dealership 3 times now. First they said it was the EGR which they apparently fixed. A few days later the light appeared again, the same dealership again charged me diagnostics and for doing a manual regen on the DPF. Today, it's appeared again. This time the dealership has refused service. Has anyone had the attached error and what have you done?
29 minutes ago, alexp999 said:
Refused service?
Yup! I think they took umbrage that I went to Ford and dearth through them and I had expressed I wasn't happy after the first time
Have you got Forscan?  That should give us a more precise fault code to work with.
I don't mate. From the diagnostics they ran the last twice it was coming up insufficient flow EGR & DPF..
Thanks but that's not really accurate enough to starting guessing parts for.  I would recommend getting Forscan as this seems to be a reccuring issue.  Will pay for itself quickly.
