focus 09 brake lights led
any one recommend any decent rear tail brake lights ?
So you don't want front face brake lights ? 🤣
so funny not
Did you upgrade to LED tail lights?  The brake bulbs are dual filament if you have the standard non-LED tail lights but single filament with LEDs.
They're also an awkward fitment in these, with offset pins, so you can't just fit any normal '382' bulb.  Need a 782 bulb with LED tail lights or 780 without.
thanks for a sensible comment.
ive got standard bulbs but trying to work out what led bulbs will fit my car
I've noticed that on more recent episodes of Top Gear, when on 'the track', cars often under heavy braking have their front LEDs flashing quickly. I always assumed it was an optical illusion that the LEDs may have reacted with the cameras, but, have they actually wired them to flash under heavy braking??
Yes, but there are two different types of rear light cluster on the Mk2.5.  The brake light bulbs are different between them.  So we need to know which yours are first.
The LED versions use an LED strip across the middle for the tail lights, but standard bulbs for indicator and brake.  (These were fitted as standard with Xenon headlights).
If you have non-LED tail lights, you'll need a red LED with a 780 offset pin fitment for the combined brake & tail bulb.
Hazard flash under hard braking has been common to many cars over the past 20 years.
DRL flash is caused by camera frame rate.
mines a mk2.5 mines not led just bulbs hth
Then you'll need a red LED in 780 fitment for the combined brake and tail light.  Won't be easy to find.  I can't see one on Autobeam.
ive searched and cant seem to find anything suitable cheersill just stick to red bulbs .
You could try these.  Though I'm not 100% sure they'll fit, or what the quality is like.
2x Red PR21/5W 567 BAW15d 780 P21/5W LED Reverse Signal Tail Stop Brake Light UK 702646208467 | eBay
Unfortunate brand name... 🤣
Talk to the guys at Classic Car LED's, not cheap garbage but will work with no hyperflash fitted them after wrapping the rears from a 2010 in mine
I’ve converted opposed pin red LED’s into offset pin fitment for my brake light bulbs.
File one pin off then 2 options, either drill a very small hole then use a small screw from kits used to repair glasses etc (possibly Rolson from Tescos) or make the second pin with some solder
Works fine on mine 👍
ok will do
