Ford Focus 1.6tdci 2009 turbo change
Hi, I’m just about to change my turbo and I’ve been advised to upgrade my inlet penilum to a later model one? Can anyone help with what this part looks like as I have a slight later donor car that’s a great runner that I’m using for spares if and when required?
I’ve added 2 pics below mine is the red circle the donor is the blue
apparently changing this prevents premature turbo failure, is that correct if so is it a straight swap?
First I've heard of it.  The only difference between those two is the intercooler bypass.  Can't see that making any difference to turbo life myself.  (IC is bypassed for a quicker engine warm up in cold ambient temps).
It's the turbo oil feed that needs replacing with a new one.  Later models are routed away from the hot DPF.  Though it's good practice to replace the feed line with a new one anyway.  It's probably chock full of carbon deposits.
In case you're not aware, there is a long procedure to follow if changing the turbo on a DV6 due to oil starvation.  PDF here - TM_Sheet 01-2014 e.indd (mahle-aftermarket.com)
