USB ports all dead??
https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=7234&languageCode=en&countryCode=USA&Uid=G1929959&ProcUid=G1929963&userMarket=GBR&div=f&vFilteringEnabled=False&buildtype=web
Can't seem to see a separate fuse for the USB ports, front and centre cubby. Does anyone know which fuse they share?
Everything else seems to be functioning, apart from a failed TPMS sensor.
Front 12V power socket is fine.
I don't know but would try F10 for wireless charger inside.
Or F32/33/34 for auxillary power point under bonnet.
The 5V supply for the USB ports is usually supplied direct from the infotainment system, so no separate fuse.
What a surprise....a MK4 Ford Focus with electrical issues...went out to see if they were still not working....back to normal!!!
Never had a car in the past 35 years that's had so many system issues!!!
I've had it a couple of times with my Sync 3 retrofit. Not sure if it's the same key combo but pressing and holding the Skip Forward buttons on both the fascia and the steering wheel reboots the unit and brings the USB port back online for me. Not sure if it's the same on the MK4 though!
