Ford Fiesta 1.6 tdci 2011
The car engine gets hot while driving. Engine performance decreases when the engine is hot. The fan starts. The car's water pump has been replaced and the radiator system has been washed. Could the fault be in the thermostat or the temperature sensor? When the engine is hot, the revs stay up for a while when you press the clutch.
thank you
Yes, thermostat would be the first thing I would check
You could still have lots of air in the system from the pump change
