drivers door handle 2007
Hi, some 'naughty boy' attempted to break into my car, pulling off the door handle and then eventually smashing the glass!!
Is the door handle just a push fit ??
No, door handle is in two parts.
The door needs to be open, then there is a small screw to remove that releases the small section of te door handle, then you can remove thw main section.
See Haynes 5566, Ch11, para13.4 - note the image of the small lever that needs to be in the correct position for replacement.
