How do i change the colour of 4inch screen?
On 10/25/2023 at 12:48 PM, tomo2001 said:
It really is a few minutes work. Try disconnecting the battery. Use spanner, job done.
So i have disconnected the battery for 2 minutes. It did not help
In order to cause a reset of all modules the battery needs to be disconnected for 20 minutes. There is enough energy stored in capacitors in the various modules to keep them alive for quite some time after the battery is removed.
I will try that today and keep you updated
So i have disconnected it for 20 minutes and still nothing changed 😞
Looks like you need a replacement IC. 🙁
  • 1 year later...
I found the answer to this question.
ford focus MK4 Titanium and ST Line basic trims that have no navigation will have the black and white IPC.
