Forscan Modifications
Hi fellow Transit owners
I’ve been playing around with Forscan trying out various modifications to my Transit Custom Crew Cab Limited 23 Plate
The modifications I’ve tried and are working are as follows
Auto Lock when vehicle goes over 15mph
Unlock one door all doors unlock
Stopped DRL from dimming when indicating
Adjusted LED DRL which goes around the Headlight to dim to 20% instead of 10% when Headlights come on (Any Brighter would be over the top and annoy other Road Users)
Have Front Fogs as DRL’s (also changed these from Halogen to LED) look much nicer
Have Front Fogs come on automatically with Headlights (Even with Full Beams) This one is a good one because the Dipped Beam lights up the middle ground and the Fogs light up the Floor. When the full Beams come into play you have the Floor, Middle Ground and Distance, the full package.
Replaced Dipped Beam with Philips Racing Vision Halogen Bulbs (Slightly Whiter and Brighter then Standard Bulbs but still Road Legal)
Replaced Full Beams with LED’s
Disabled the Seatbelt Reminder
Changed the Splash Screen from the Boring Ford Logo to the ST Performance Logo
Tried various other Mods but was unable to get them to work like changing the number of Indicator flashes from 3 to 5 and Auto Fold Mirrors
You’re welcome to have the Forscan codes I’ve used
All the Modifications I’ve made I’ve made sure they don’t annoy other Road Users
Regards Assad
Regards Assad
Finally plucked up the courage to remap from 130 Bhp to 170 Bhp
  • 3 weeks later...
Hi Assad, could you tell me how you turnt off the DRL dimming as I’ve fitted the drl headlights and need to turn on the dimming also how do you turn off the seatbelt chime thanks in advance
  • 5 months later...
Did you do this using forscan
Assad??
On 10/5/2024 at 3:38 PM, Craig l said:
Assad??
  • 3 months later...
My 2023 custom 130 bhp doesn’t like the 170bhp map , it’s a bit jumpy at low revs when pulling off ,but perfect with the original 130bhp map
  • 8 months later...
Regards Assad
I'd appreciate the codes.
  • 6 months later...
Regards Assad
Regards Assad
Regards Assad
Where can you find the codes
You don't need codes they're just enable/disable settings in each module that controls the functions
I suspect some of it, especially these two:
You can only configure DRLs to either work in the headlamp OR fogs as DRLs, not both
Fogs on automatically doesn't work on EU Fords only some old F150s (Bambi Mode)
And you can only activate power fold mirrors if you have power fold mirrors fitted and if you did they'd be activated anyway
And you can't remap using FORScan
So I'm taking a pinch of salt
