Ford Galaxy 2008 Airbag Recall With a Remap
Hi all,
I need to take my car to Ford for the Airbag recall,
My car has been remapped with DPF off and EGR a new ECU and a few other bits done,
Will Ford have to Re-Flash my ECU-PCM to do this work? I am worried that they will have to reflash the car and it won't even start for them Id have to get my mapper to re-take the ECU out and bench map it again or recovered from Ford if they did so,
Has anyone had the airbag recall done on a Ford Galaxy or similar 2008 and can confirm they Do or Don't Reflash the car, Can I request them not to do any updates to the car as its Eco remapped while at the dealership?
Thanks all.
As far as I know this is a physical parts replacement recall. There should be no need to "reflash" anything.
Perhaps Ian @iantt might know the answer.
https://www.ford.co.uk/support/how-tos/recall/recalls-and-faqs/what-is-the-takata-airbag-recall
Thanks for the reply, I was thinking the same was more then likely going to be a physical replacement, I can always get the map done again anyway worse comes to it, an Airbag recall seems more important in the long run than a map getting wiped.
Cheers!
PCM (which is mapped) is completely separate to Airbag (SRS) so I wouldn't worry
