p02fa 85-28 Error code
Hey all
ford focus 2.0 tdci 2015
The code apparently has something to do with the Diesel Intake Air Flow Position Sensor , just wondering if anyone has any knowledge on this , dont know if its causing an issue , buit my 2 rear abs sensors have failed so i plugged in my reader and found this code was also there , hoping its an easy fix ?
Does anyone know where this enssor is even located ?
TIA
no ones seen this before ??
I think that's an old Code. Try clearing it and see if it comes back.
If it does then if you get set up with FORScan you may be able to Live Monitor the Valve. It may not be moving at all or maybe it needs to go through a Learning procedure for the PCM to set the fully open and fully closed points.
  • 3 weeks later...
Hi. I have cleared it a few times and it keepa coming back , if it needsnforscan , i guess itll have to go in the garage.
wiring problem to the MAP sensor  im having sim issues with my focus i have given the car to 2 so called auto electricians and both told me wiring was ok, i did some self teaching and found out both where wrong i have a broken earth wire going to the throttle valve that i cant find. id start at the map and maf sensor to confirm continuity of all wires now the map sensor is intermittently failing sending the car into limp mode apparently these wires can break around where the harnes is held to the gearbox you said you had a code reader ? can it read live data if not forscan is free for 2 months and you can pick up a cable for around €30
https://www.amazon.com/dp/B094Z7PBLS
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
