Fuel Temperature Sensor Ford Fiesta 1.5 TDCI 2015
Hello!
My Fiesta won't start when the engine is hot, but it start when it cools down.
Got there errors:
->P228C -> Fuel Pressure Regulator
Changed both Fuel Pressure Regulator, but this didn't fix the problem.
->P0093 -> Here is a problem with one of the injectors
-> P0183 -> Fuel Temperature Sensor
I think this is the problem, but i can't find where is located Fuel Temperature sensor.
I can't find anything about Fuel Temperature Sensor, can someone help me?
The fuel temp sensor is part of the low pressure pipework.  It's not sold separately.  If you follow the plastic pipework from the filter you should find a small black rectangle with a 2 pin electrical plug.  That's the fuel temp sensor.
This one? Or this is something else?
Thank you!
Thank you!
Yes, I think that's it.
Thank you!
Still won't turn on when engine is hot. Any ideas?
