Adding cruise control on MK4
Hello everyone. I just bought a 2019 Focus MK4 and it is the style verison ( UK cheapest version). It is a 1.5 manual diesel 95hp. The problem is that I don't have the cruise control function. I have only the LIM button. The car has camera for lane assist and collision break. What I need to do for me to have Cruise control function? It is enough if I Buy from ebay a SH steering wheel with Cruise control function or will need programming after installing?
Yes, change the steering wheel button to one with cruise, as in your photo. You will need to make note of the part number before you fit it.
In FORScan you will need to change the part number of the LH steering wheel button, so it knows it's there ( I think that's in IPC)
Then turn on cruise control in central configuration
Thank you for your help. But let say in case I will change the whole sterring wheel I will need to change the part number of the right buttons ( multimedia one) as well?
If you swop the wheel and the RH buttons are identical then you don't need to worry.
You will still need to see the part number of the LH buttons to configure
Thank you again for you help.
