Engine overheating
Engine runs fine but after idle for a few minutes the water in the small diameter pipe to the top of the reservoir is boiling causing boiling water to escape from the reservoir cap. Any ideas please.
Not qualified to comment only I'd get it checked ASAP something blocked
water pump or thermostat. dose the fan kick in ?
No fan doesnt
check that your getting power to the fan could be as simple as a fuse or relay
