What’s this?
So had an annoying oil leak on the fezza since day1. Mechanic said it’s from back of engine so will be rocker cover gasket. Had that change and it still leaking oil. Cam shaft seals are dry there’s nothing on the timing belt. When you feel the back of the timing cover it’s covered in oil though! There’s a switch or sensor there two that’s covered in oil also. Any ideas anyone? Attached a pic for the switch or sensor
Camshaft position sensor.
