Focus 2019 ST-Line. Both headlights out. Full beam working ?
Hi there Focus ST Line 2019 . Both main beam headlights have stopped working . The led side lights still work in both settings and the full beam is also working . Both headlights seemingly went out at the same time . Bulbs look ok
When i have main headlights switched to on the side lights are dimmer , when i put just side lights on they are brighter ....when i indicate left or right the corresponding sides side lights are then dimmer when the inidicator is flashing ....Havent checked any fuses ? Fuse ? Relay ?
40 minutes ago, TrickyH said:
Bulbs look ok
Replace the bulbs, or at the very least remove them and test with a multimeter.
Both stopped working at the same time
It is not unusual for both to need replaced at the same time.
......and ?
Perhaps @StephenFord can offer some words of wisdom ? 🤣
  • 1 year later...
Hi Tricky, did you get to the bottom of this? i have exactly the same on my 2019 model.
Side lights go dim when i put headlights on etc.
Without details of the model, spec, and year this is just a waste of time.
