Juddering
I have a ford focus 2012 1.6 diesel, it judders when pulling away in first gear, but only when the engine gets hot, can any body help
too little info
could be loads of stuff
engine mounts
clutch plate hub springs broken
oil contamination on the clutch
but being a tractor, check codes and general servicing
and clean the EGR
2 hours ago, Botus said:
too little info
engine mounts
and clean the EGR
The. Only other thing I can think of is I've had a coolant leak from the thermostat housing which is above the gearbox.
I bought an s-max ex auction with the juddering problem showing when starting to move from standstill.
Lower revs when dropping the clutch successfully masked the issue, which disappeared in a short space of time.
The car now shows just short of 250k miles on the clock without having any remedial work for this initial problem.
