Engine won’t start. Engine system fault high temperature
07 fiesta 1.4 petrol
Lights left on so battery completely flat.
battery pack used and instrument panel now lights up, but no crank, attempt to turn over. nothing.
red flashing light flashing 1:6 code
engine system fault high temperature messages appears.
Had AA out and said it was immobiliser and tried several re-sets.
but no joy.
keys work fine and tried both.
battery shows good voltage.
fuses ok.
Any help ideas appreciated.
Disconnect the battery negative lead for at least 20 minutes.
When you reconnect it, WAIT for 5 minutes before turning on the ignition.
Hello thanks for reply.
the AA chap did a similar thing which he disconnected for 12 mins I think and then leaving the ignition to position 2 for a few minutes. Nothing happened.
with the test mode I get
DTC 1  C100
DTC 2 E510
engine is cold so not sure why the high temp message comes up along with engine system fault.
You need to get the real full Ford diagnostic trouble codes (DTC's) using FORScan. Only then will you be able to get a proper diagnosis.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Thank you so much!
I did this and got it started.
however there was a blown fuse in the glovebox fuse box which I also replaced.
looks like I’ve got a oil leak now though as I was tinkering around and pulled out some plug which appears to make some oil leak out.
been googling this but can’t find out what this socket/cable/plug is called.
