Fiesta MK7 Esp off connector
Hello Everybody. I own a Ford fiesta mk7 pre facelift from 2012. Mine came without an ESP off switch. I purchased one from Ebay to fit to my Car atfermarket. Its an Ford Original part. I have the odd feeling, that it is actually for the Facelift version of the MK7, because after hooking it up and installing it correctly, nothing happens. Can anybody provide me with a picture from The back of an Original MK7 ESP off switch? I think the Facelift version uses different pins than the old version. Any Help would be greatly appreciated! Thanks in advance. I hope you can help me somehow!
Kind regards,
Karl From Germany!
Have you used FORScan to enable the option of the switch ?
Hey thanks for the reply… No i haven‘t enabled it yet. Everywhere i looked, Everbody said, it was plug&play. Apearently isn‘t 😅 Where can i Enable it in FORScan?
I've not looked for the setting in FORScan for your model, but I would check out the BCM and the PCM
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
I‘ll take a look… Do you think, that the non standard button could cause problems like those?
I would think it is probably the same switch, so all that needs to be done is to tell the car that it now has one fitted.
Hey mate. I‘ve spent the last hour looking through every signle Firscan menu and entry. I found nothing. It really seems to be plug&play as i thought. I figure if i can find a picture if the connector from the original button, i can fugure out the pins, the button connects to.
