Loud Static through speakers
Hi
I’m randomly getting loud static through the speakers when the stereo is on both on listening to the radio and Bluetooth connected then it will pop and just not work. The screen will also go blank
I’ve had this, replaced acm and been fine since. You will need to remove yours to get the correct part no, last letter  should ideally be the same or higher than yours, I actually used one one letter lower but worked ok.
