Alloy wheel damage
Hi
I have a 2023 fiesta Ecoboost. I recently caused kerb damage to the edge of  wheel which is like to fix. Can anyone advise me whether the highly polished spokes are an applied finish or just highly polished alloy please
Regards Roger
This type of alloy used to be diamond cut, but they looked awful after one winter of road salt, so Ford started painting them to 'look' diamond cut instead.  If you can post a picture of the damage, we should be able to confirm whether it's painted or not.
IMG_20241030_125743674.thumb.jpg.cf36f2cd65861a6552b94499f71fc69c.jpgThanks for your reply. Photo attached. Do you think that it's repairable
Regards Roger
I think those ones are actually diamond cut.  They can still be repaired with a small graze like that, but the process is more involved than paint.  Basically the wheel gets laid flat on a lathe and then a diamond tipped blade passes over it to cut the top face perfectly flat again.  Then they need to be covered in clear lacquer to prevent them corroding.
It isn't really possible to carry out a small touch up on this type of finish so won't be cheap.  As it's still quite new, did you get any wheel insurance from Ford when buying it?
