Sat Nav issue - 2011 Focus
The red arrow on my sat nav is not following the roads I'm driving on. I can see the road names and street names, but the arrow is driving through streets, over mountains and through rivers! Any thoughts on what is causing this and solutions? I have tried the manual calibration, but it never completes.
GPS aerial fault by the sounds of it.
Is that easily fixed?
Yes usually.
Firstly you need to check using FORScan for any Diagnostic Trouble Codes (DTC's).
It could be a fault with the aerial amplifier/isolator module or simply the aerial.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Try a manual reset. I had this issue but was resolved by resetting
