MK1 Focus MK1 1.6 petrol 150k
Heater only works on the highest setting 4, the fan is also making a squealing noise
When trying on setting 1-3 I hear a squealing noise but the fan is not running
Any ideas what would cause this fault?
Fan resistor for the loss of settings 1-3.  But the squeal must be a separate fault.
2 hours ago, ash29109 said:
MK1 Focus MK1 ....
Does two Mk1's make a Mk2 ? 🤣
As Tom has already said it just needs a new resistor pack. That's a quick and cheap repair.
Someone might have a few photos they could share @StephenFord 🤔
Seeing as you asked so politely 🤣 sub £10 on Ebay...
Squealing from Blower Fans is often the Fan Bearings, more common when the Fans were in the Engine Bay and exposed to the elements.
If you can access the position of them without to much dismantling then give them squirt of oil.
