OEM Reverse Camera wiring diagram
Hi everybody,
I have 2011 Ford Galaxy that used OEM Reverse Camera with gray, 6-pin Hirose "GT17VS-6DS" connector (old version).
camera_plug_old.jpeg?w=320&tok=669b1a
(p1 - old version)
My camera corroded and water came in the camera motherboard so I had to buy a new camera.
I've find that Ford is now using same camera with green, 4-pin Fakra "HSD" connector (new version).
rfk_neuer-stecker.jpg?w=320&tok=456b5d
(p2 - new version)
So, I bought this OEM Galaxy/SMAX/Mondeo camera with Fakra HSD connector and I came with problem that I have this old camera cable:
kabelbaum_modul_alt.jpg?w=320&tok=8c0661
(p3 - old camera cable that connects RFK module and camera cable)
and I need this 6-pin connector to remove and solder the wires to the new 4 pin connector:
rfk_stecker_neu_modulseitig.jpg?w=200&tok=bdd3b1
(p4 - this male 4-pin connector should replace the old 6-pin connector from the picture p3 above)
kabelbaum_modul_neu.jpg?w=320&tok=e0e423
(p5 - so the cable should looks like this)
FINAL QUESTION:
I need original wiring diagram for this FAKRA male and female connector !!!
Can anyone confirm that this wiring scheme from this two pages are correct:
Car electrician helped me to solder the wires using the wire diagram from above but wherever I put the gear into reverse -> camera won't switch the picture to reverse cam.
We also tried this:
  • we took working 3-party camera and connect it the same way as on this video, but we don't have picture on the navigation unit:
Is there any FUSE that needs to be changed or something that will make camera to display on the nav unit.
Many thanks in advanced !!
