Grand Tourneo Connect 1.5TDCi wet belt?
I am in the process of purchasing a 2020 Grand Tourneo Connect 1.5TDCi. My report says that it has the ZTGA engine. Does this have a wet belt for the timing? Many thanks in advance, I'm sure you guys get asked this alot! I have attached a picture of the actual engine bay for reference.
This is the 1.5 EcoBlue engine.  It does not have a wetbelt.
It uses a normal dry belt.  Plus a small chain for the cams.  This chain has been known to break regularly and there is a thicker upgrade chain available if you ever decide to replace it.
  • 9 months later...
Hi.
I have just bought a 2020 Grand Tourneo Connect 1.5TDCi and have been told that it is NOT a wet belt. I have spent a lot of time researching this and have found so many different answers. If possible could someone please confirm which belt I have? And how do I find out if the engine that is in mine is the ZTGA engine. It would be much appreciated.
Ang
16 hours ago, AJ Newton said:
Hi.
Ang
The engine code is written on the V5 logbook. And originally on a sticker at the top of the cambelt cover, although those fall off over time.
A 2020 model will most likely be EcoBlue rather than TDCI. So dry timing belt. Plus a small cam-chain that is known to be weak. There is an upgraded 8mm chain that can be fitted for peace of mind if desired.
