Ford Galaxy 2.2 egr valve location 2009
Hi hope someone can help where is the location of the EGR valve ?
To remove and clean.
many thanks
Behind the engine.  Right at the top.  Not sure there's enough access space between engine and bulkhead to remove it on these.
Hi, the Ford Galaxy EGR Valve is located on the engine's intake manifold, near the throttle body. I have attached a few images to help you out also I will attach a link to a place where you can get a new one if needed. Hopefully this helps you out hi.
