Oil change diy Ford Galaxy 2021 2.0 diesel
Hello,
I did change oil on my Ford, took some photos, I hope can help someone.
  1. I lifted the car from one side, for better access
  2. Oil filter is below engine, in front side, so you take down the shield. Good to have aku skrewdriver, there are many screws in star and two plastic fasteners you need to lift a bit first.  But after that it has really good access
  3. I tried to untighten the filter with hand but no chance. Bought an improvized tool, but did not work that well. Definitelly have a key for oil filter.
  4. Oil drinage screw, nice one, easy to take out and has a rubber seal. I like it more compared to copper or aluminium
  5. I took out 6 liters of old oil. I expected to be less, but with filter and filled to full probably it is normal
  6. Have around some paper, there is high chance you spill some oil around
  7. Took about two hours, including search for filter key in the town. Next time should be less than an hour
Good day all.
Silviu
Just my advice...
  • 1 month later...
Did my 2019 again today, not a bad job to do. Did a double oil change again by draining the old oil and replacing with new and a filter, started up and ran for 5 mins and drained again new oil filter and oil, expensive but at least the oil is clean on dip stick now
  • 2 months later...
What is the round container to the right for oil filters.
S-Max 2021
Ivan
Denmark.
S-Max 2021
Ivan
Denmark.
Diesel fuel filter.
7 hours ago, TomsFocus said:
Diesel fuel filter.
Well you live and learn. I was thinking it was for storing the Lurpak butter in 🤣
