Replacing S-Max computer
I have a 2010 S-Max. The computer has gone off it's rocker . . it keeps telling me the 'luggage compartment' is open when its not, and then locks it, so I cannot open it.  Then random things that don't make any sense . . . I have reset the ECU several times by disconnecting the battery, and it worked . . for a while . . then went back to its old ways.  I am tired of trying to sort the computer out.   Is it possible to replace the computer?
You need to employ an 'Auto-Electrician' to correctly diagnose the fault(s).
is it mostly boot-related issues?
if so - check the wiring in the left hand grommet from car to boot
is it more...everything?
check the BCM under glove box for signs of water ingress
...water ingress from failed washer pump, 2nd row large connectors?:
ECU can be tested if above does not compute...
  • 4 weeks later...
Drat another OPW for the Club! 😉
Let me give them the Golden TW award 🤣
