No sound
hi guys and gals. Is there any reason all my speakers would fail all at once. There is no sound at all from any of them not even static. I have a 13 plate 2.0 tdci basic model. I have taken the factory unit out and replaced it with a Sony that I know has no issues. Thanks in advance. 😁
Sure the basic model came with speakers fitted? :biggrin:
If you've got a multimeter, check the continuity through any or all of the speakers from the headunit plug.  There's nothing smart about speaker wiring, they're just a coil of wire at the end of the + and - wires.  If they've got continuity, they should be able to produce sound.
It is possible for a very loud sound to blow every speaker at once...but seems unlikely in this case.
Has the OP checked the battery in their hearing aid ? 🤣
Hey guys…change my hearing aid battery and turned it up 😁 taken the door card off the drivers door and attached a different speaker. One I know works. But still nothing
I'm a bit confused
Did it only stop working after you changed the head unit for a Sony one?
And was the Sony actually from an S-Max/Galaxy/Mondeo? There are compatibility issues with other models.
