Door locks
Hi all,I’ve got a ford smax titanium sport 2012,when I lock it all doors lock but when I unlock it drivers front door and passenger rear door doesn’t unlock,you car hear the door mechanism working but don’t seam to be unlocking any ideas thanks
  • 3 weeks later...
Hi, did you get anywhere with this?  Probably need to take the door card off and see what's happening when you lock/unlock the car.  Do you have ForScan?
I have a similar issue, mostly when the car is cold, and I occasionally see this fault code, which suggests to me that the motor is on the way out
===PDM DTC B110B:15-68===
Code: B110B - Rear door passenger side central locking motor
Additional Fault Symptom (:15):
 - Circuit Short To Battery Or Open
Status (-68):
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
Module: Passengers Door Control Unit
 Freeze Frame  #1:
-EVENT_TIME: 18373043 s (Wed Jan 07 08:55:14 2026) - Event time
-TOTAL_DISTANCE: 200136 km - Total Distance
-MODULE_VOLTAGE: 12.8 V - Control Module Voltage
===END PDM DTC B110B:15-68===
