  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
S-Max/Galaxy 1.6T Ecoboost fueling faults
I'm turning to forums now 🤦 I've seen some very similar threads but not the same I'm yet to try one other thing before I write this off as a lemon!
2012 galaxy 1.6 ecoboost
Current fault codes
P0089 - fuel pressure regulator A performance
P0300 - Random multiple cyline misfire
P0302 - cylinder 2 misfire
P0303 - cylinder 3 misfire
P053f - cold start fuel pressure performance bank 1
Before the car worked it's way to me it's had a new in tank pump, new injectors, new pressure regulator, new spark plugs.
I've replaced the High pressure fuel pump and I've checked every is plugged in, connected, fitted, screwed, bolted and so on.
Now I'm scratching my head think wtf could it possibly be now 🤷 I've read the ecoboosts are notorious for having shoddy fuel pump control modules? Is that my next bet??? Or do I go back and double check all the work that has supposedly already been done?
