Intermittent adaptive headlights fault
As per title, my car as developed an adaptive headlights fault. It can happen as soon as I turn the car on or it can be fine for an hour drive. But when it happens, I get a nice dashboard warning and it locks the headlights front (no more turning as you turn.
Turning the ignition off for a bit clears it but again only for a bit.
I wouldn't mind but it also disabled the high beam which I believe makes it an MOT failure. Thank you Ford for that bit of anti-consumer.
I've reset the HCM multiple times. No fix
I thought it might be a battery issue as the start/stop wouldn't work either (battery would never get above 68% charge).
Replaced and reset BCM. Start stop works now but the intermittent headlight remains.
I've had to a local garage (I am NOT paying ford Diag fees 😁). They can't find anything wrong. Putting the headlights in test mode has they moving fine and smooth so it's not the motor/servos.
I was going to start looking for another headlight unit but before I do, I thought I'd see if anyone has any ideas? Is it worth just changing the control board rather than the whole unit? Is it actually worth having ford take a look for £160 diag fee?
tried forscan? i bet its one of the level sensors on the front wishbone or rear wishbone
