U0001 High Speed CAN Communication Bus
I keep getting an Engine Malfunction error on the dash on my Focus Titanium, then I get the Acceleration Reduced message when the car goes into limp mode, the traction icon is left on the dash. When I pull over and turn the engine off and wait for a minute and then turn it back it can sometimes then go another 30 mins to an hour without an issue but it does keep coming on after this.
I have taken it into 3 garages for a diagnostics reading but no one can tell me a specific issue as they say it could be a number of things.
What would be the best way to go about resolving this?
Were any of those Ford garages? Ford specific diagnostics might be able to show more faults as many are hidden from generic garage scanners.
Though as this is a Mk2 Focus, there's a high chance of it being a cluster solder fault.
Ford Instrument Cluster Repair Service, Focus / Fiesta / Mondeo / etc | eBay UK
Thanks Tom, I could do with trying that, none of the garages were Ford garages. I did contact a Ford garage and it was £100 to have a look with no guarantee of a solution but maybe that is the only option left other than buying a new car.
You can cheaply get set up on FORScan and read the codes yourself
FORscan looks quite interesting, I will have a look on youtube on that one, thanks for your help.
You could try giving a bash to the top of the dash. If that provokes the fault or changes it that would pretty much confirm it's cracked solder joints in the instrument cluster.
Hi, this has indeed affected the error, normally when the malfunction occurs, it takes 20 seconds or so to then go into limp mode, if I bang the top of the dash as soon as it malfunctions it then goes into limp mode straight away.
Then you indeed need the cluster repairing.
Contact @rd457 on here, he'll sort you
Here's a link to my service: https://www.ebay.co.uk/itm/314393033915
Can absolutely recommend this
Hi, thanks for your reply, but I just wondered if there was an alternative to removing the dash and posting it off, I would prefer to drop the car in somewhere to be fixed, do you know of anywhere in the S Yorkshire area that would specialise in this?
No I don't, sorry. There are some other people/companies offering similar services but I don't happen to know where any of them are based.
You could always take it to a garage, they could then take it out, you or they could then post it to me, and then they can refit it afterwards. Just so long as they're okay with your vehicle sitting around in their property for a few days. (I wouldn't advise letting them attempt to do the soldering themselves, some might be willing to try but they usually don't have the skill or suitable tools to do a good job).
I had the same problem .... managed to solve it by myself - cracked solder joint on PCB - main loom socket.
The PCB is not that hard to take out! Go for it --- don't be afraid, just take it slow, step by step. You might discover something new about yourself!🫣
Not sure I would dare, do you reckon that is 100% the issue though, I get the Engine Malfunction warning and then it normally pauses 30 secs until it says Decreased Acceleration, but if I hit the top of the dash it changes immediately, but it is still in limp mode unless I turn engine off.
i'm 99,999% sure. i had the same symptoms. Also it's a common fault. What's your mileage?
Does your car drive normally? My had no power loss... but then again, i did not drive a lot after the warnings started...about 5 times it happened, then i opened it up.
I was my first time too. Well, i do quite lot of wrenching for a home repair guy, also i'm pretty good with the soldering iron, but i'm pretty sure you'll be able to pull it out. If you have 2 hands and you can screw out a torx screw, you're good to go. Be gentle with unplugging the socket, prolly have to unhook it with a small screwdriver..
I forgot the exact details as i did the same on our 2008 S-max, so i have it mixed up in my head a bit...
Alternatively, do you have any field diagnostics / auto-electricians anywhere near? the guys that come over to where you're at...
  • 5 weeks later...
I think I have found someone local who can solder the cluster, I will have to remove this myself, will I have to uncouple the battery first?
It won't hurt
I got the cluster out ok and got someone to sort the solder and this seems to have worked, as I have had no engine malfunction warnings since.
The only issue I now have are the needles on the dials, the Speedo being the main one which is way out. When I put the cluster back in and started the engine it was out so took it back out and moved it around to zero again and left myself option of moving it when plugged into car but still it is out. Do I have to remove this again to calibrate?
When power is fully removed (unit unplugged), the needles aren't supposed to point at zero, their resting positions are slightly below zero, then when power is applied (plugged in), they'll be moved up slightly, at which point they should point at zero. Getting them back in the right positions can be a very fiddly and frustrating task, especially since the gauge background can move slightly, and putting the cover back on can shift it.
That's the downside of getting a random electronics repair person to do the soldering rather than someone like me who specifically repairs these ICs - they won't necessarily get the needles back in the right positions for you, or they'll mess it up because they don't know that resting position is not zero.
It is virtually impossible to position the needles correctly with the instrument cluster removed.
Back in the days I repaired dozens of these instrument clusters. Initially I always used the following method (which always worked great):
Preparations: Make sure the fuel tank is completely full and the engine has reached its normal operating temperature before you start.
1: Remove the instrument cluster from the car.
2: Remove the front cover and remove the needles.
3: Install the instrument cluster into the car (without the front cover and needles) into the car.
4: Switch the ignition on.
5: Install the fuel gauge needle at the correct position (full).
6: Install the temperature gauge needle at the correct position (depending on engine type, just before or on 90 degrees Celsius)
7: Switch the ignition off.
8: Put the instrument cluster into test mode and switch the engine on.
9: Scroll through the test menu to the digital engine speed and position the tachometer needle according to the shown digital value.
10: Take the car for a drive. Only perform the next step on a private road or an industrial estate without any other traffic!!
11: Scroll through the test menu to the digital vehicle speed and while maintaining a steady speed (preferably on Cruise Control, if the vehicle has Cruise Control) position the speedometer needle according to the shown digital value.
12: Now test everything thoroughly during the drive. Adjust the needles when needed.
13: Remove the instrument cluster from the car.
14: Install the front cover.
15: Install the instrument cluster into the car.
When done correctly the gauges are usually even more accurate than they originally were.
After I repaired 5 or so of these instrument clusters, I build myself a CANbus controlled test setup to be able to install the needles on the bench.
After reading a tutorial on it this is the way I did mine:
After removing the panel from the housing gently move the needles back until you feel them hit the mechanical stops (the stepper motors have these internally). Place pieces of masking tape on the dial face and mark the position of the needles whilst ensuring they're still against the stops. Then, when reassembling, line up the needle positions with the marks with them at the stops.
I didn't worry too much about absolute accuracy for the fuel and temperature gauges although these worked out pretty well. My tacho is very slightly out - again not a serious worry - and I made sure the speedometer needle was pretty much spot-on. If it over-reads fractionally (say, a needle-width) that's obviously less important than under reading. It's vital it doesn't under-read.
Of course this will only work if the needle positions are correct before starting the repair.
ON MY 06 MK2 THIS ISSUE WAS SOLVED BY RESOLDERING DRY JOINTS IN THE INSTRUMENT CLUSTER ,MANY VIDS ONLINE ALSO A FELLA BY THE NAME OF OLLIE JONES WAS DOING REPAIRS VIA POST , NOT SURE IF STILL GOING BEEN A WHILE .
If you'd read through the whole topic you would have seen that he's had it resoldered and resolved that issue.
And by the way, posting in all capital letters is regarded as shouting.
