Please help! This only happens on cold start
Hello everyone , i hope you can help me solve this issue. I have a 2012 Focus MK2.5 with Duratec 2.0 HE. I will attach a youtube link to show you the problem. Thank you in advance
PS: Scanner shows error code P0133 , slow response on O2 Sensor B1S1. Thats the only visible code
Edited by darkknight96
What do the dash warnings mean in English?
Has the battery been checked?
"It's broken"?
But seriously, I can't even make out what language it is - the pause/play symbols on my device screen are right over the text so I can't freeze it to read it!
12 hours ago, TomsFocus said:
battery
Yes , i've already checked it. The dashboard says "Insert key , press stop" , that was because i pressed the button to turn off the engine
This morning i tried again but did something different: as soon as i heard the engine crank , i lifted my foot on the clutch. Sorry for my bad English , i hope you can understand
Ok. I was hoping it said 'press brake'. Which would have pointed towards a faulty clutch pedal switch.
If the battery is also good then I do not know what's causing this.
It could be the common cluster solder starting to fail but if this is the only fault you can see then even that is not very certain.
The other day i disconnected the ECT sensor and started with no issues , that gives me the hint that could be something related to a bad mix on cold. I've already replaced this sensor , do i need to reset the ECU so it can read the new values?
Unplugging the temp sensor just makes the ECU run a default value. That can mask other faults. It does not prove the sensor is faulty.
There is no reset for this type of sensor. It should just work immediately after changing. Do you have any tool that can show the exact ECT readings?
