Windows and mirrors stoped working
I have a 2006 ford focus 3 door hatchback version. I went thrue the fuse box and replaced some bad fuses. And i put the gey into the ignition and turned the key 2 noches without 2 fuses. I turned the car of and put the fuses back. After that my windows,mirrors and the rear window cleaner stoped working. It all worked before and now it doesent. I again went thrue the fuses again and all are good. I cheked the relays in the engine bay but i didnt have the ones i ternet said i needed.
Idk what to do no more
Check you’ve not disturbed any of the main fusebox wiring connections while you’ve had the fusebox dropped down for access. These can also suffer from corrosion over time if water gets in past the harness grommet.
