Transit connect 1.6 tdci fuel issue
Hi everyone
My connect has recently had a low fuel issue.
Changed the filter and rail sensor.
Was just the same... hard to start, rough idle and stalling.
Garage diagnostic said high pressure fuel pump failed. With possible injector damage but recommended change pump and see where it is.
Ive had the pump changed, starts fine now. Will run for various periods up to 1 min then stops.
Runs ok under revs..
Any help appreciated
Still air in system, don't attempt to bleed if fuel level low, at least a quarter of a tank
It has half a tank, bled up fine and started
