Little Advice, Wing Mirror Replacement...
Hi all,
I had a little accident in the Fez which resulted in this:
The mirror functions are fine, other than the glass being smashed obviously.
I can replace the glass easily, but i also need the white casing at the back, the black plastic lip that surrounds the glass, and the plastic that covers the indicator.
My question is, where is the best place to get these replacements? and can i get away with not having to buy a whole new wingmirror??
Thanks in advance,
i look forward to your replies.
I had a bit of an accident with my wing mirror last month, and the mirror was fine, the electrics were fine, the case itself was fine, but the bit on the base unit that lets you attach the casing was broken.
it cost me £190 (including labour) to have it fixed.
Don't know if that helps you or not.
