Mk5 1.25 Unable To Select Fifth Gear
Got a Mk5 2001 1.25 and it is able to select all gear fine except for fifth which if selected when the clutch is let up it just makes a crunching like sound as iff it's not quite selected properl. I've adjusted the linkage as per haynes and still no better.
Do you think this is a linkage or a gearbox issue? How do I ascertain which it could be bar the obvious which would be to replace the linkage unit completely!
Many thanks in advance for any help and advise that can be given.
A common fault is worn selector on the fifth gear this leads to a worn gear
Can be changed without removing gearbox if this is the problem
OK, thanks for the info. ;)
